router failed to boot
Jan 29th, 2008
the router fails to boot, it start and give me the below exceotion message with no code. is this a software or hardware failure?
it stops/fails before you can break and change the config!
System Bootstrap, Version 11.0(10c), SOFTWARE
Copyright (c) 1986-1996 by cisco Systems
Paolo Bevilacqua Tue, 01/29/2008 - 07:44
Is that an old 2500?
Perhaps it was sitting there because faulty..
The only thing you can try, remote the ram and check if it goes any better.
amays3 Wed, 02/06/2008 - 01:13
thank for your reply, I was leaning to a hardware problem but I was not sure so I'll crack it open and get to work. thanks
