PPPoE session RADIUS VRF
Jan 29th, 2008
I have to deploy the following scenario:
PPPoE Sessions terminated on a 802.1q GEth Subinterface on a 7206 Router.
It should be possible to put some customers (based on domain name) into a VRF (vrf-lite) instance.
The vrf-id should provided by a Radius Server.
Has anyone a similar config to give me a feedback or a useful link) ?
Thanks and regards,
Thomas
ebreniz Mon, 02/04/2008 - 10:45
You can assign VRF membership to virtual-access interfaces using
a) Cisco-avpair = "lcp:interface-config#1=ip vrf forwarding "
Cisco-avpair = "lcp:interface-config#2=ip unnumbered loopback"
or
b) Cisco-avpair = "ip:vrf-id="
Cisco-avpair = "ip:ip-unnumbered="
Option a forces full Vaccess interfaces, option b works with virtual-access subinterfaces, but is not supported in all releases..
http://www.cisco.com/en/US/docs/ios/mpls/configuration/guide/mp_vpn_half_dup_vrf.html#wp1099246
d.pehar Wed, 02/06/2008 - 08:32
I have the same problem on Cisco 10008.. it seems that it can't go without RADIUS server.
Domagoj
