User defined task RME 4.0.5
Jan 29th, 2008
I m trying to make in RME-config mgmt-net config new user defined task which copy the startup-config to E.g disk0:.
Problem is how can i tell when creating user defined task that after command "copy startup-config disk0:" do enter when switch asks "Destination filename"
Any idea
Juha
Overall Rating: 5 (2 ratings)
jobidondave Tue, 01/29/2008 - 08:18
Add the following command in config mode;
"file prompt quiet"
and then, retry your copy, you should not get back the prompt "destination filename"
u346874_2 Tue, 01/29/2008 - 21:02
No help for these "R" or "file prompt quiet" commands. Logging says "Jan 30 06:48:59.008 EEDST: %SYS-5-CONFIG_I: Configured from tftp://10.x.x.x
/20080130064540593-10.x.x.x.cfg by console"
Somenthing happens but startup-config i cant see in slot0:.
Juha
