Remove Password encryption
Answered Question
Jan 29th, 2008
i have applied the following command in the config mode : service password-encryption
how can i remove it ? so that the passwords are no longer encrypted ?
Correct Answer by Collin Clark about 9 years 1 month ago
Andriy is correct. Since these are VTY passwords they must be removed then re-added. You could also reverse the password since these passwords have weak encryptions.
Correct Answer by Richard Burts about 9 years 1 month ago
Tarek
Collin has given exactly the right answer. But it may not seem that way when you apply the no service password-encryption command. Be aware that this command turns off password encryption. But that passwords that have been encrypted and stored in the config as encrypted will remain encrypted even when you turn off the service. The only way to get those passwords into clear text is to configure the passwords again after the service for encryption is turned off.
Rick
Correct Answer by bilousand about 9 years 1 month ago
Once encrypted passwords will stay so until you cancel encryption with no keyword AND enter them from command line again.
Overall Rating: 5 (3 ratings)
Collin Clark Tue, 01/29/2008 - 08:20
  • Purple, 4500 points or more
With most Cisco configurations, the no keyword removes the command.
HTH and please rate
majdalani Tue, 01/29/2008 - 08:30
yep i know that, and i have tried that, but the password is still encrypted, i even type wr mem, closed the session, telnet to the swicth again, and it is still shown :
line vty 0 4
password 7 01100F074F
login
line vty 5 15
password 7 00071A0510
Correct Answer
bilousand Tue, 01/29/2008 - 08:31
Correct Answer
Collin Clark Tue, 01/29/2008 - 08:33
Correct Answer
Richard Burts Tue, 01/29/2008 - 08:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Tarek
Rick
majdalani Tue, 01/29/2008 - 08:45
Hi , Thanks to all.
I have understand it now.
yep i change the password once again and the password appeared again.
Thanks again,
Tarek
