01-29-2008 08:41 AM - edited 03-18-2019 08:23 PM
VM's are working fine but hear message when accessing Messages (see subject). I've ran the Syscheck and only the Domino stuff fails plus:
Failure Exchange2K
Failure Exchange55
Can anyone shed any light?
Cheers,
Rich
01-29-2008 09:08 AM
Hi Rich -
I'm confused by your post ... When you ran the Message store configuration wizard on Unity, what server did you partner Unity with - Exchange or Domino? It cannot be both.
Ginger
01-29-2008 10:06 AM
Hi Ginger,
We're using Exchange 2003.What I meant was I would expect the Domino tests to fail because we're using Exchange!
Can you help?
Rich
01-29-2008 10:26 AM
Hi -
Ahh, now I understand. Next time you run Syscheck, you can skip the areas that don't apply. Are you seeing any errors in the Application event log, that indicate Unity is having problems connecting to Exchange? Check this directory to see if you have voice messages there - (default location) c:\commserver\UnityMTA. If you see voice messages here and no errors in the Application event log, try restarting the AvUMRSynchSvr service.
Ginger
01-30-2008 01:42 AM
Hi Ginger,
Sorted. Bridgehead server had no route back to Unity.
Thanks for help.
Rich
