Translation Route to VRU failure
thomas1
Level 2
Level 2
I'm getting the following message on the Router process window:
TranRoutetoVRU failed. Unable to map route 5010 to a network VRU
I know that 5010 is the service I've selected in the "Trans Route to VRU" node. Any idea what I have configured wrong? What should I check? I can't figure out how I specifically map the "route" to the network VRU. I must be overlooking something.
Thomas
Riccardo Bua
Level 5
Level 5
Hi Thomas,
usually there is one default Network VRU being defined per installation, do you have one? Seems like you might have an IVR peripheral but no Network VRU defined.
Riccardo
