IOS load Problem
Jan 29th, 2008
Dear sir
I have one Aironet 1200 access point and I wanted to reset it password but unfortunately my IOS have found problem and it cannot work and I want to load the IOS again , according to the manual I did as follow but there is some problem would you please let me know what I should do in this case.
First
ap: set IP_ADDR 192.168.133.160
ap: set NETMASK 255.255.255.0
ap: set DEFAULT_ROUTER 192.168.133.1
Second
tftp_init
Third
tar -xtract tftp://XXX.XXX.XXX.XXX/c1200-k9w7-tar.123-8.JA2.tar flash:
But after last step it gives me this error message
tftp://XXX.XXX.XXX.XXX/c1200-k9w7-tar.123-8.JA2.tar: connection timed out
With best regards
Hamed yazdi
Rob Huffman Tue, 01/29/2008 - 10:15
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Hamed,
Sounds like a TFTP problem for sure :(
Have a look at the details in the following threads that all have to do with TFTP. There are some great hints for troubleshooting TFTP problems from some of my favourite NetPros like ScottMac,Stephen from Cisco and Jack Young. The likely culprit may be that you need to uncheck "hide extensions for known file types" on your TFTP server;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=WLAN%20Radio%20Standards&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddc042b/8#selected_message
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=General&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddc03c4/2#selected_message
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=General&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddbf271
Maybe try this (highly recommended version)
Solar Winds tftp
http://www.solarwinds.net/Tools/Free_tools/TFTP_Server/
The problem could be that the Laptop (used for TFTP) Operating System is hiding the known file type. From Internet Explorer, go into Tools > Folder Options > View, scroll down until you find the parameter Hide extensions for known file types, and uncheck the box. This should eliminate the issue.
Hope this helps! Good Luck!
Rob
hamedyazdigss Tue, 01/29/2008 - 15:44
dear sir
i cheched all the option are same as things that u mentioned and i as said before when i want to use the TAR command after a sce it gives me a timeout error again.what do u think in this case and i am sure my labtop and tftp are corect.
with best regards
hamed yazdi
manjesin Tue, 01/29/2008 - 18:05
Hi Hamed,
We notice connection timeout message on AP communication problem between two machines
* Pls check do we notice any logs on tftp server whete
AP is not able to communicate with tftp server... you can get this confirm by looking at the logs on tftp server.. if not that there is not request coming for AP to tftp server.
* Pls disable the windows firewall or if there is any norton software running on computer on which tftp server is running.
* Make user tftp server ip address is in the same range as AP ip address.
* Last option connect tftp computer directly to AP and try.
* Try different ethernet cable
Try tftp server which cisco recommends:-
www.tftpd32.jounin.net
Rate if these step works so that other can take benefit of this forum ..
