CAR and CDR.
Hi all,
I have enabled all reporting related services (CDR schedular and web) on CCM 5.1 also I have activated "CDR Enabled " and "Call Diagnostic" flags.
whenever I try to generate a report the system will display the following message "Data is not available in the Database".
even I cannot view any report if they are automatically generated or customized.
B Regards,
Mo.
v.gotsev Tue, 01/29/2008 - 13:45
I have the exact same problem. And dont have solution yet.
Jaime Valencia Mon, 02/11/2008 - 21:16
  • Cisco Employee,
  • Hall of Fame,
    2011
are you guys running a user report or a CDR report?
try 1st with CDR reports to find out if there is data in there
tomorrow i can post a qry you can use to look directly into the CAR DB and verify if there is any data in there
