Error message
  • Unable to create CTools CSS cache directory. Check the permissions on your files directory.
MCU H.323 configuration Help
Jan 29th, 2008
I have installed a 3515 MCU, and i want it to be used by H.323 endpoints (they are aleready registerd with callmanager).I don't have a gatekkeper. What configuration steps should i proceed in the callManager and in the MCU in order to enable H.323 endpoints make Multipoint Video conference via the MCU?
Please it urgent!
ebreniz Mon, 02/04/2008 - 11:27
  • Silver, 250 points or more
To configure a Cisco device as an H.323 gateway in a service provider environment, configure at least one of its interfaces as a gateway interface. Use either an interface that is connected to the gatekeeper or a loopback interface for the gateway interface. The interface that is connected to the gatekeeper is usually a LAN interface: Fast Ethernet, Ethernet, FDDI, or Token Ring.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_configuration_guide_chapter09186a00801fc997.html#wp1006922
