CCNP Expires on feb 18 2008 Please clear my problem
Jan 29th, 2008
My CCNP will expire on Feb 18 2008 I am preparing for CCIE R&S Written I am writing CCIE R&S on 15 Feb 2008 if I fail, Again I had to write CCNA & CCNP. Please clear my problem.
best regards
Brandon Buffin Tue, 01/29/2008 - 12:08
That is correct. If you do not renew your CCNP by the 18th, you will have to retake the CCNP exams and the CCNA assuming it expires at the same time. You might consider scheduling a CCNP exam for Feb 16 or 17 in case you fail the CCIE written. If you pass, you can cancel the other exam.
Hope this helps. If so, please rate the post.
Brandon
