Ospf security for area 0
Hello
take a look to this Scenario:
if you 2 switches connected togather via l2 etherchannel(Port-channel 2) and there are 2 interfave vlan:
int vlan 50
ip address 192.168.50.1/24
int vlan 51
ip address 192.168.51.1/24
those interfaces on both Switches.ospf as routing protocols.now if i want to use the security to secure area 0
the config should be under the Intrface vlan or under the Port-channel 2?
many 10xs
Overall Rating: 5 (1 ratings)
Kevin Dorrell Tue, 01/29/2008 - 11:22
  • Green, 3000 points or more
OSPF security is applied on the Layer-3 entity; so on the vlan interfcaes. The layer 2 etherchannel has no idea of OSPF - it isn't concerned with IP routing protocols.
Kevin Dorrell
Luxembourg
