How to change the manage,ment IP on AIP-SSM ASA5520
Answered Question
As the title says how do you cahne the management IP? I was told we could change it but now we can't access the device after reloading it to reset the password.
the current management IP is invalid.
IPS ver 6.0.3
ASA ver. 7.2.3
Correct Answer by marcabal about 9 years 4 months ago
You need to use a comma instead of a space between the netmask and the default gateway.
"10.1.1.13/24,10.1.1.1" instead of "10.1.1.13/24 10.1.1.1"
Overall Rating: 5 (3 ratings)
acomiskey Tue, 01/29/2008 - 11:14
  • Green, 3000 points or more
You can session to the SSM module from the ASA.
ASA#session 1
login:
password:
SSM#config t
SSM(config)#service host
SSM(config-hos)host-ip /
Getting invalid input when trying to change IP address. It looks like I'm following the format , any ideas?
the ^ is under the 10 in 10.1...
sensor(config-hos-net)# sh setting
network-settings
host-ip: 10.1.9.201/24,10.1.9.1
host-name: sensor
telnet-option: disabled
access-list (min: 0, max: 512, current: 0)
ftp-timeout: 300 seconds
login-banner-text:
sensor(config-hos-net)# host-ip 10.1.1.13/24 10.1.1.1
% Invalid input detected at '^' marker, The ip interface configuration, 10.1.1.13/24, format is invalid
Correct Answer
marcabal Tue, 01/29/2008 - 11:44
  • Cisco Employee,
