translation-rule
Jan 29th, 2008
Hi Pro.
i have a CME router.
the number we are receiving in directory without 00 in front and the user cannot dial from directory.
i have to create translation rule incoming,so that it changes all the incoming international number with 00 in front.
thxx
Overall Rating: 3.7 (3 ratings)
Jaime Valencia Tue, 01/29/2008 - 12:29
it's a little tricky since you never know how many digits you're going to receive but you can try something like this:
voice translation-rule 1
rule 1 /\(^.......$\)/ /\1/
rule 2 /\(^..........$\)/ /\1/
rule 3 /\(^.*\)/ /00\1/
voice translation-profile profile1
translate calling 1
dial-peer voice 10 pots
translation-profile incoming profile1
incoming called number .
7 & 10 digit incoming will match rule 1 or 2 and anything else will match the last rule which will add the 00 in front of the received digits
sandeep pokhriyal Tue, 01/29/2008 - 12:41
Thxx for reply..
We have 8 digits dialing inside the country and we dont have codes for cities. I want translation rule for international and i dont wanna change anything with the local numbers. Also we are not using 9 to dial outside.
Jaime Valencia Tue, 01/29/2008 - 12:47
this won't affect outside dialing, just how the call is presented to the called party for incoming calls
rule 1 /\(^........$\)/ /\1/
rule 2 /\(^.*\)/ /00\1/
if everything else incoming is only 8 digits change it like above, the 1st rule will always match 8 digits and won't add anything, anything that doesn't match that, will be prefixed with 00
sandeep pokhriyal Sun, 02/03/2008 - 01:09
hi..
sorry for being late i was not in the town..
i tried this one but its not working..
In the "incoming called number" promt what should i write,the DID number range.
when i tried putting this translation rule to one of the extension then the DID calls were not coming to that number.
voice translation-rule 2
voice translation-profile profile2
translate calling 2
dial-peer voice 123 pots
incoming called number 0788
the calls to extension 788 stopped working..
we are using primary extensiona as 0788/
Paolo Bevilacqua Tue, 01/29/2008 - 13:05
That works fine for me:
rule 1 // /00/ type international international
The important thing is that incoming international are correctly marked as such in the setup message.
sandeep pokhriyal Tue, 01/29/2008 - 22:15
hi i have COR list for outgoing numbers..
i will post the dial-peer config here..
i have one more issue here..and i relate it with dial-peer probably as i understand..
when i call a PSTN number which is switched off, the calling number gets callback tone and keeps ringing though it should say the number is not reachable
Paolo Bevilacqua Wed, 01/30/2008 - 01:43
what you get when calling numbers that are "switched off", depends by telco, and you cannot do anything about it.
The COR list has nothing to do with the translation-rule question, have you tried it ?
