wlc 4402 sesion logoff
Jan 29th, 2008
hello. how do i avoid that ask me to WLC authentication from time to time? i want autenticate once and that sesion doesn`t expire until i court (or logoff.
i looked at options and configuration of the wlan is like:
Sesion Timeout................0
Re-Authentication Timeout.....0
Remaining Re-Authentication...Timer is not running
But every now and then it disconnetes me anyway.
Is it necessary to change the settings in the network this option:
User idle timeout......300 seconds??
Thank you.
ivillegas Mon, 02/04/2008 - 11:43
  • Silver, 250 points or more
Session timeout should do the trick. Generally reauthentication is meant for clients. In this case save the configurartion and try rebooting the controller by unplugging the power and then reboot it.
Trending Topics - Security & Network
