IPCC Enterprise information/database
I have 2 questions about IPCC Enterprise :
1- I Use CAD (Cisco Agent Desktop) with IPCC Enterprise. I want the agent to transfer the customer call, after asking him some information, to an external number. I want to get the call duration after its transfer to the external number. How can I make this possible?
2- I need to retrieve customer data from external database and display it to the CAD (about 20 fields to display). What are the alternatives to make this possible ?
I am thinking about 2 possible solutions (Application Gateway with ICM or CAD Integrated Browser with web page to display the information). Any suggestion ?
Abdulbaseer Mohammed Tue, 01/29/2008 - 14:53
  • Silver, 250 points or more
how are you doing this transfer and external means outside your group or network?
Is the transfer going throgh PSTN? is there a compatiable and or similar platform on external end?
Riccardo Bua Wed, 01/30/2008 - 07:48
  • Cisco Employee,
You should do a consult transfer with an IVR and have the ICM leg disconnect before doing the transfer if you wish to hold your reports under control and to provide you the right figures, otherwise you might get numbers that would not match properly the calls treated.
It is easier to use then an integrated browser from CAD to collect the info or place them in whichever workflow/call variable you wnat to retain.
Riccardo
david.macias Wed, 01/30/2008 - 06:04
  • Blue, 1500 points or more
1. If the call is being sent out of ICM's control then I don't see how you will be able to retrieve any call information from it.
2. I recommend your second approach. I've used the integrated browser to launch a website and make a query and it works great.
david
Javier Cuadros Fri, 02/13/2009 - 07:32
hi aketata, i just wanted to know how you handled the display of information on the cad desktop for the agents since i'm needing to do something like this, byt just need to display the call type for incomming calls
Javier Cuadros Fri, 02/13/2009 - 07:52
thanks for you answer, but then you are working with IPCCX, i need the call variables under CAD but with IPCC Enterprise have a clue?.
