I've got a hosed 1131ag...I think
So I've got a 4402, which I've configured and everything there should be good to go.
I associated a new 1131AG this morning. I used DHCP to give out IP addresses, and manually input the WLC IP Address into the AP via the LWAPP command.
The AP has since disacciated from the WLC. There are no APs registered in the WLC. In the AP, I can't get into any of the LWAPP commands, nor can I execute clear ap private-config. Hitting Escape during boot process while it's loading the IOS image is fruitless, as is Ctrl-Break.
Any help would be much appreciated.
- Mike
