01-29-2008 01:46 PM - edited 03-03-2019 08:28 PM
I have been informed that I can use one of the switch port in 871 to connect another WAN there. Is there any possibility I can actually use that for another or backup WAN connection if there is a way let me know a configuration link will be helpfull.
01-29-2008 04:09 PM
First of all you need the "advanced ip services" image, configure an additional vlan interface, and assign the port you want to it with "switchport mode access vlan XX".
Then, having dual ISP setup with redundancy can be a little complicated, however your starting document is:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a00808d2b72.shtml
Note, the title is really misleading. The example does redundancy, but not load balancing.
01-29-2008 06:53 PM
yes, you must configure a rest vlan interface to differentiate vlan be used by lan.
