MGCP with server config and no dial-peers
Answered Question
When mgcp config is downloaded from CCM, is there a need for the (pots) dial-peers anymore? The MGCP gateway is 3845 router with 12.4 IOS and the CCM has version 5.1. The router has eight T1 PRI ports (to PSTN) but the CCM has not created any dial-peers for the voice ports. Do I need to create them manually?
The calls from/to PSTN seem to be working (there are small issues though).
ioan
Correct Answer by mciarfello about 9 years 3 months ago
PRI ports won't show up as dial-peers on the router.
Analog POTS FXO's and FXS's usually do have dial-peers like below:
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0
Overall Rating: 5 (1 ratings)
Rob Huffman Tue, 01/29/2008 - 16:19
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi ioan,
One of the nice parts of using MGCP is that dial-peers are not required :)
How to Configure MGCP with Digital PRI and Cisco CallManager
http://www.cisco.com/en/US/tech/tk1077/technologies_configuration_example09186a00801ad22f.shtml
Hope this helps!
Rob
Hi Rob,
Thanks for your reply. If I understand correctly, if ccm config is used AND if "isdn bind-l3 ccm-manager" is present under serial port, there is no need for dial-peer (which would bind the respective voice-port to mgcp).
However, from what I know, in all Cisco docs presenting "manual" mgcp config, the dial-peer(s) binding the voice-port(s) to mgcp is always present.
Please correct me if I'm wrong.
ioan
Correct Answer
mciarfello Tue, 01/29/2008 - 18:11
  • Silver, 250 points or more
service mgcpapp
port 0/1/0
