how to whitelist a specific email address
chuntmd_ironport Tue, 01/29/2008 - 15:25
A Content Filter would be the easiest but it is processed after the SBRS check.. Remember you can have a one content filter with multiple checks just make sure you use OR and not AND.
So if you want to make sure a specific email is not spammed check you would need to create a Message Filter (regX expression) but then every single inbound email would be checked againest this filter.
So the best way might be to create a whole new policy and place it before your normal or default policy. Have the policy only apply for sender = [email protected] You can turn off the spam check for this policy.
Pat_ironport Fri, 02/01/2008 - 10:14
Just to be sure:
I need something similar for 2 specific sender-adresses from a domain @example.com
Should it work, If I create a new "Incoming Content Filter" and Add the following rule (using two single conditions with an OR and the Deliver-Action):
if (mail-from == "[email protected]$") OR (mail-from == "[email protected]$") { deliver(); }
Then I enable this new "Incoming Content Filter" for my default "Incoming Mail Policies".
How can I test it without asking the two "real" sender?
What do you exactly mean with "processed after the SBRS check"?
Knuto0815 Mon, 02/11/2008 - 10:51
Something that has been quite useful to me is the overview of the email pipeline (kb answer ID 777).
