My VPN doesn't work.!!!
Jan 29th, 2008
Hi All,
I configured a sample VPN in a 2611 Router to connect via Cisco VPN Client Sfw from a Remote PC on internet.
When the tunnel is estabilished, all networks stop to work in my PC.
I can't access the LAN inside.
Could anybody help me to solve this problem ?
Follow my config :
version 12.3
service linenumber
hostname mtech_lab_rt1
boot-start-marker
boot-end-marker
enable password xxx
no network-clock-participate slot 1
no network-clock-participate wic 0
aaa new-model
aaa authentication login LOCALUSERS local
aaa session-id common
ip subnet-zero
ip domain name xxx.com
ip cef
ip audit po max-events 100
username dticsco password 0 xxx
ip ssh time-out 60
ip ssh authentication-retries 2
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group HOME
key xxx
dns 192.168.0.4
domain xxx.com
pool CLIENT_ADDRESSES
crypto ipsec transform-set MTECHVPN_SET esp-3des esp-sha-hmac
crypto dynamic-map CLIENT_MAP 1
set transform-set MTECHVPN_SET
reverse-route
crypto map MTECHVPN_VPN client authentication list LOCALUSERS
crypto map MTECHVPN_VPN isakmp authorization list LOCALUSERS
crypto map MTECHVPN_VPN client configuration address respond
crypto map MTECHVPN_VPN 100 ipsec-isakmp dynamic CLIENT_MAP
interface FastEthernet0/0
ip address 192.168.0.130 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
ip address 41.x.x.15 255.255.254.0
ip nat outside
duplex auto
speed auto
ip local pool CLIENT_ADDRESSES 192.168.2.1 192.168.2.10
ip nat inside source list NATLIST interface FastEthernet0/1 overload
ip nat inside source static tcp 192.168.0.6 25 41.x.x.15 25 extendable
ip nat inside source static tcp 192.168.0.6 110 41.X.X.15 110 extendable
ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 41.x.x.1
ip route 192.168.0.0 255.255.255.0 FastEthernet0/0
ip access-list standard NATLIST
permit 192.168.0.0 0.0.0.255
dial-peer cor custom
line con 0
location work
exec-timeout 30 30
password cisco
line aux 0
password cisco
line vty 0 4
login authentication LOCALUSERS
transport input ssh
end
AB
Antonio Brandao Wed, 01/30/2008 - 00:03
Hi Arul,
I did not understand how i will apply this this information in my scenary.
Do you have sure that is same scenary ?
Please notice that in my topology, i have a router that receives a VPN from remote teleworks, in diferents subnets, and is not a scenary point to point how explain the example that you sent.
AB
dominic.caron Thu, 01/31/2008 - 06:27
  • Silver, 250 points or more
What Arul said is not bad. Even if it's not the main cause of your problem, your DNS will not be reachable from the tunnel.
Every answer to your client from your DNS will be NATed. Your client will not accept it.
Antonio Brandao Thu, 01/31/2008 - 06:42
Hi Dominic,
Sorry, but i don't understood .
Im newbie in VPNs.
In the pratice what i have to do to my network become visible to my vpn client.
Wich is the NAT rule that i have to create.
Tks.
AB
Antonio Brandao Mon, 02/04/2008 - 09:16
version 12.3
service linenumber
boot-start-marker
boot-end-marker
enable password [email protected]
aaa new-model
aaa authentication login USERAUTHEN local
aaa authorization network GROUPAUTHOR local
ip subnet-zero
ip domain name mydomain.com
ip cef
username antonio password 0 tonhao01
username dticsco password 0 dt!czc0
username ricardo password 0 ric123
username belarmino password 0 bneves0511
ip ssh time-out 60
crypto isakmp policy 3
encr 3des
group 2
crypto isakmp client configuration group MTECHVPN
key [email protected]!zz030459
dns 192.168.0.4
wins 192.168.0.4
domain mydomain.com
pool ippool
acl 101
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10
set transform-set myset
reverse-route
crypto map clientmap client authentication list USERAUTHEN
crypto map clientmap isakmp authorization list GROUPAUTHOR
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
ip nat inside
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
ip local pool ippool 10.1.1.10 10.1.1.20
ip nat inside source list 111 interface FastEthernet0/1 overload
ip http server
ip classless
access-list 101 permit ip 192.168.0.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 111 deny ip 192.168.0.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 111 permit ip any any
line con 0
location work
exec-timeout 30 30
password 7 02050D480809
line aux 0
password 7 0822455D0A16
line vty 0 4
login authentication USERAUTHEN
transport input ssh
end
