Remote VPN
attrgautam Tue, 01/29/2008 - 23:16
  • Silver, 250 points or more
Hardware VPN device can be used for LAN2LAN and remote login IPSec while VPN Client can only do Remote login. Also, having HArdware VPN device will allow multiple users to communicate through the same IPSec tunnel and also allows the same device to form multiple IPSec tunnels to different hubs - While with a VPN Client you can form only a single session at a time to a concentrator.
Let me know if this helps
