ajagadee Tue, 01/29/2008 - 18:28
MPLS is not supported on SUP 1A. If you are running a very old code, you might see the commands in the code and configuration options but in the newer codes for SUP 1A these features were removed and are not supported.
Arul
** Please rate all helpful posts **
