How to get multiple phones in a request with SelectCmDevices
Caigang1234
Hi all:
I had met this problem, i can get only one phone with this request:
"<soapenv:Envelope xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\" " +
"xmlns:soapenv=\"http://schemas.xmlsoap.org/soap/envelope/\" xmlns:soap=\"http://schemas.cisco.com/ast/soap/\" xmlns:soapenc=\"http://schemas.xmlsoap.org/soap/encoding/\"> " +
"<soapenv:Header>" +
"<AstHeader xsi:type=\"soap:AstHeader\">" +
"<SessionId xsi:type=\"xsd:string\">1234567</SessionId>" +
"</AstHeader>" + "</soapenv:Header>" + "<soapenv:Body>" +
"<soap:SelectCmDevice soapenv:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">" +
"<CmSelectionCriteria xsi:type=\"soap:CmSelectionCriteria\">" +
"<SelectBy xsi:type=\"xsd:string\">Name</SelectBy>" +
"<Status xsi:type=\"xsd:string\">Registered</Status>" +
"<Class xsi:type=\"ns1:DeviceClass\">Phone</Class>" +
"<Model xsi:type=\"xsd:unsignedInt\">255</Model>" +
"<SelectItems>" + "<Item>" + macadd +
"</Item>" + "</SelectItems>" + "</CmSelectionCriteria>" +
"</soap:SelectCmDevice>" + "</soapenv:Body>" +
"</soapenv:Envelope>";
But how can i to get multiple phones in a request? i had tried many methods, but all of them are not work. Thanks for any helps!
Caigang1234
Does anybody know that? Thanks in advanced!
If you don't have any items in selectItems, it will return you first 200 phones.
Hi msabir:
Thanks for your help. Yea,i don't want to get the first 200 phones, i just want to get the phones which are listed in the items.For example:
"SEP0013192F15DU"+
"SEP000E839C1479"+
"SEP00131A4D3B34"+
"SEP001D450BF4CF"
,then i just want to get the four phones, but when i do like this,i always just got one phone,why is that? Then i changed to use Array like this:
"10"+
"Phone" +
"255" +
"Any" +
"Name" +
"SEP001D450BF4CE"+
"SEP00131A4D3B34"+
But it alway throws this error:
soapenv:Server.generalExceptionERROR: SelectBy is null
why? Thank you very much!
Does anybody know that? Any help is very precious!
