Not able to access web server behind PIX 515E version 6.3(5) with two inter
Jan 29th, 2008
I have a PIX 515E UR version 6.3(5) with two interfaces. I am not able to access the web server behind it.
Please help me in this regard.
I am attaching the running configuration and the network details
ohanusi2000 Wed, 01/30/2008 - 05:18
i can not see anything wrong with your config
was this ever working ?, make sure the default gateway of the server is pointing to the pix.
Make sure the service are running on the server , try connecting locally to this services.
if the nat is in use before try clear the xlate
and clear arp on the cisco and pix, if the gateway way change (new cisco was installed)
reginelluvelil Sat, 02/02/2008 - 10:13
This is a new Cisco pix 515E.I am configuring the first time. The DG is pointing to the pix.
I can connect to the websever from inside by using http://192.168.100.10.
i have issued the clear xlate and clear arp commands
what could be wrong?
help???
thanks in advance
regi
reginelluvelil Tue, 02/05/2008 - 09:07
hi all,
I solved my problem myself.
I just upgrade my PIX to 7.2(1). I can access the Webserver behind the PIX 515E now.
Thanks a lot
Regi
