QOS for point-point ASA 5505
Jan 29th, 2008
Hi experts,
I got a point to point ASA 5505 and wanted to configure qos since only the ip phones is using it.
Any recommendations? do really qos effective in WAN links?
tnx
Anonymous (not verified) Mon, 02/04/2008 - 13:26
To effectively implement priority queuing for VoIP, you should always configure rate-limiting (policing) as well to drop traffic that exceeds a specified level. Priority traffic is not rate limited. Policing is required because the ASAdoes not support traffic
shaping. This means that there is no backpressure on the flows to limit the amount of traffic being sent. Thus, without policing, priority queing really only has an affect if the ASA's interface becomes saturated. Then priority traffic is sent over non-priority
traffic. However, in most cases the ASA will be connected to a switch via 100MB/Full duplex. But the upstream connection to the Internet is much less than 100Mb/Full duplex. So there won't be much queing on the ASA interface, but the upstream device will drop the packets (unless it supports some type of QoS). .
http://www.cisco.com/en/US/docs/security/asa/asa70/configuration/guide/qos.html
