01-29-2008 11:12 PM - edited 03-17-2019 09:15 PM
How can i connect my existing PBX having 200 extension with the CIsco IP Telephony Solution. I checked VG 248 but it only allows 48 Ports. IS there anybody knows about it.
Solved! Go to Solution.
01-30-2008 04:09 AM
Because it is quite expensive (about USD 150 per port or more) to use analog gateways to connect basic phones, and for about the same price you can get a basic IP phone, most people prefers to do a technology jump and not use the analog phones anymore.
Anyway in your cause you would just use four units of VG248 to cover 200 analog extensions.
01-30-2008 04:09 AM
