error : slot 0 failed
rajesh1331
when i give the command sh flash in my router (7206) it gived the output "open device slot0 failed (no such device)"
Is it any hardware error?
thanks and regards
Rajesh
Jon Marshall
Hi Rajesh
No it's not a hardware fault. If you want to see where you images are stored do a
router# dir all-filesystems
This will print out all the files and tell you where your image is stored eg. from one of our 7206vxr routers
7206_vxr#dir all-filesystems
Directory of archive:/
No files in directory
No space information available
Directory of system:/
13 drwx 0 its
125 dr-x 0 lib
2 dr-x 0 memory
1 -rw- 1319 running-config
12 dr-x 0 vfiles
Directory of nvram:/
123 -rw- 1078 startup-config
124 ---- 5 private-config
125 -rw- 1078 underlying-config
1 -rw- 0 ifIndex-table
2 ---- 34 persistent-data
129016 bytes total (125833 bytes free)
Directory of disk1:/
1 -rw- 20321344 Nov 14 2005 16:26:30 +00:00 c7200-p-mz.124-5.bin
2 -rw- 16091792 Dec 9 2005 21:43:54 +00:00 c7200-p-mz.123-16.bin
47955968 bytes total (11538432 bytes free)
Directory of bootflash:/
1 -rw- 4431932 Sep 30 2003 06:36:48 +00:00 c7200-kboot-mz.121-8a.E
7602176 bytes total (3170116 bytes free)
7206_vxr#
As you can see IOS images on disk1 so you can now do
router# dir disk1:
Jon
Pavel Bykov
Level 5
Level 5
To see what file systems you have available, issue the following command:
"show file systems"
Where there are numbers - there is storage. Dashes means there is nothing there.
In your case "FLASH" is just a symbolic link to device "Slot0", you really don't have to worry. Just use Slot1 or Bootflash.
