Get 2 VLAN's to talk on Cisco 3560
Jan 30th, 2008
Hi, I have a Cisco 3560 24 port switch. 12 ports are in VLAN 2 which are home to a few PC's and a couple of servers and a Cisco 877 DSL router for the Internet and firewalling. I have created a VLAN 3 to home 4 Mac's, however how can I get these to speak to VLAN 2 for the servers and get to the Internet? I want to keep this design and not move the Mac's into VLAN 2 as this all my grow and I like to keep the Mac's separate due to broadcasts.
Overall Rating: 5 (1 ratings)
Jon Marshall Wed, 01/30/2008 - 00:52
The 3560 should route between these vlans automatically. So in this example
vlan 2 = 192.168.5.0/24
vlan 3 = 192.168.6.0/24
1) make sure ip routing is enabled on the 3560 eg
3560(conf t)# ip routing
2) Ensure that the L3 vlan interfaces are created on the 3560
int vlan 2
ip address 192.168.5.1 255.255.255.0
int vlan 3
ip address 192.168.6.1 255.255.255.0
3) default-gateway of machines in vlan 2 = 192.168.5.1
4) default-gateway of Mac's = 192.168.6.1
5) The 877 router will need to know how to route back to vlan 3 so unless you are running a routing protocol, on the 877
ip route 192.168.6.0 255.255.255.0 192.168.5.1
Jon
