PIX506 site to site VPN
Jan 30th, 2008
I have 3 pix 506 firewall to configure for 3 sites mesh topology. All the PIXes are sat behind the firewalls with NAT enable. each site have their own firewall. There are Sites A, B, and C. Site A is using Netscreen firewall with NAT, Site B is using Checkpoint with NAT, and Site C is using Linux IPTables firewall with NAT. All the PIXes 506 will site behind (inside) firewall, Is this possible? If yes, Do you have a sample for this configuration.
Many thanks
obacati21 Wed, 01/30/2008 - 06:34
Yes it is possible. The conf is as simple as full mesh VPN topology. The diferrence is that your need to use STATIC TRANSLATION on each firewall and an access-list for incoming traffic (ESP, udp/500 and udp/4500).
REgards
OB1
