Disaster recovery / CAR
Jan 30th, 2008
hi
Please do clarify me if we can take the backup through disaster recovery in CUCM 6.0(1a) and put that in the secondary server[subscriber] directly ie to give the subscriber server as the network path for the backup device, provided i install the SFTP software in Subscriber.
Also the cdr was not generated if i give a date range and it shows me a message that data is available only for an older date range.Also when i try to search for the cdr of a user/extension, i get a message that there are no matching records found.
Please do help me to solve this ..
sadbulali Tue, 02/05/2008 - 07:00
The Disaster Recovery System (DRS), which can be invoked from Cisco Unified CallManager 5.0 Administration, provides full data backup and restore capabilities for all servers in a Cisco Unified CallManager cluster. The Disaster Recovery System allows you to perform regularly scheduled automatic or user-invoked data backups. DRS supports only one backup schedule.
The Cisco Disaster Recovery System performs a cluster-level backup, which means that it collects backups for all servers in a Cisco Unified CallManager cluster to a central location and archives the backup data to physical storage device.
When performing a system data restoration, you can choose which nodes in the cluster you want to restore.
The Disaster Recovery System includes the following capabilities:
"A user interface for performing backup and restore tasks.
"A distributed system architecture for performing backup and restore functions.
"Scheduled backups.
"Archive backups to a physical tape drive or remote sftp server.
The Disaster Recovery System contains two key functions, Master Agent (MA) and Local Agent (LA). The Master Agent coordinates backup and restore activity with all the Local Agents.
The system automatically activates both the Master Agent and the Local Agent on all nodes in the cluster.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/5_0_4/drsag504.html#wp149713
kumar3880 Tue, 02/05/2008 - 20:17
hi
Can you please let me know if i can make the subsccriber as the backup device[to store my backup]
regards
kumar
rasheedccvp Tue, 02/05/2008 - 11:06
CDR problem:
Install the latest engineering special for CUCM 6.0, then it will be resoved.
