DHCP IP address reservation
Jan 30th, 2008
I have a dhcp pool for - 254 on a cisco 3750 switch.
I want to reserve some specific IP address for some specific machines / persons. So that those machines always get the same IP and that IP doesnt get assigned to another machine.I want to give specific IPs to managers etc.
Overall Rating: 4 (1 ratings)
m.sir Wed, 01/30/2008 - 05:22
You will need to configure separate DHCP pool per client
ip dhcp pool PC1
client-identifier xxxx.xxxx.xxxx PC1 MAC address
default-router x.x.x.x
ip dhcp pool PC2
client-identifier xxxx.xxxx.xxxx PC2 MAC address
you need to specify the MAC address of each host and the associated IP within each pool...
For rest of users you can crate one pool with network specified
Hope that helps rate if it does
munawar.zeeshan Wed, 01/30/2008 - 05:56
i have a long list of clients for reservation.it will be a lengthy process.
Any shortcut or some script ?
