problems upgrading flash on 3640 (16 to 32MB)?
Jan 30th, 2008
  • Blue, 1500 points or more
I have a client who needs to upgrade their flash on a 3640 from 16-32mb in size. Will this at all affect the IOS that's currently installed in flash? ie, will it still boot up into the existing
IOS?
currently there's a single 16mb flash stick, and they plan on adding a second 16mb simm flash.
TIA
Overall Rating: 4 (1 ratings)
srue Wed, 01/30/2008 - 07:01
Thanks, but that's pcmcia flash. I'm trying to see about on board flash simms.
cpubob Wed, 01/30/2008 - 07:40
  • Bronze, 100 points or more
AFAIK, or remember, you can add the second chip without affecting the bootup of the box, but, I would highly recommend at least setting up an alternate boot source in case something bad happens and you loose your internal ios. This can be external flash or even a tftp server and the appropriate boot statement to allow a secondary boot via tftp. At least this will guarantee you won't be left in the dark after the upgrade. You will of course have to reformat your internal flash after you boot so you will loose your ios then but as long as you don't power down, you should be ok.
I would recommend the tftp boot method if you do not have pcmcia flash available.
boot system flash c3600-image
boot sys tftp c3600-image 10.x.x.x
Try the flash, and if that fails, load the helper image and try the tftp.
GL
-Bob
srue Wed, 01/30/2008 - 07:43
great, thanks for the advice...
