CCME Bulk Edit
Answered Question
Jan 30th, 2008
Using ccme 4.1. Customer wants speed dials,(more than 99) I have created a Bulk edit file and it all works o.k. The problem I have is that on a fairly regular basis the customer needs to update the file to reflect adds/changes made to the users. The only apparent way to do this is to go into telephony-service take out the existing file ref and load the new changed file. it seems a long way around, Is there no way the system can fetch the contents of the file upon request rather than just load a copy into memory? ( I have placed the file on a company server and referenced this on the gateway as a tftp location.
Correct Answer by paolo bevilacqua about 9 years 3 months ago
There is no provision in CCME to automate the process.
So you will have to build a macro in some software to simplify the operation.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Wed, 01/30/2008 - 06:55
  • Hall of Fame,
    Founding Member
