Consolidate two Unity 4 servers into one Unity 5
Answered Question
Jan 30th, 2008
I need to consolidate two Unity 4 systems into a single Unity 5 server. Each Unity 4 system has approx 1500 subs and 70 call handlers. I'm not aware of any upgrade path for this situation so the plan is to build the new unity 5 server, recreate the call handlers, sub templates manually then run bunny killer to split the AD accounts from the old servers and then bulk import them into the Unity 5 system.
I'm looking for a way to avoid recreating all the call handlers manually. Bulk Handler create doesn't look terribly helpful since the caller input settings cannot be specified.
Just wondering if anyone knows of an easier way to do this that I may have missed.
thanks
Correct Answer by Markus Schneider about 9 years 2 months ago
Depending on your timeframe for doing this, there may be another option. Take a look at:
http://www.ciscounitytools.com/App_COBRAS.htm
Overall Rating: 5 (1 ratings)
Tommer Catlin Wed, 01/30/2008 - 09:12
  • Green, 3000 points or more
This looks to be your tool. I would however have you notice that it is not tac supported yet. When you calculate your time, calculate how long it will take you to rebuild each callhandler manually. This tool though, should be able to import, export, etc.
I would give it a try for sure. And watch the videos. I just did and they are great. And like Jeff said, email him with questions or problems with the tool.
cheers
kseraphine Wed, 01/30/2008 - 10:20
COBRAS seems to be what I need. I'm not sure how it slipped under my radar; I hadn't seen it before.
Thanks for the info
