Call Manager 5.1(3) : Cannot boot, and cannot be reinstalled
Jan 30th, 2008
I'm using a IBM eServer 306m (MCS-7825-i2).
The problem is that after a reboot, the system cannot boot. It is blocked after activating the SWAP partition.
It Display "Activating SWAP Partition [OK]
And after it freeze.
So i've tried to re-install the Call Manager. I've used th Installation Disk.
But It cannot be installed.
The CD can verify the disk sanity,
and after that it verify the BIOS SATA-RAID.
and it said that the verification is complete.
And after the system freeze too.
The installation cannot continue.
2 -
So I've compared the boot with a second Call Manager.
And I've seen that after Activating SWAP partition, the system verify the IBM BIOS.
Have you any solution?
Many thanks
