"no ip route cache" command
Jan 30th, 2008
I would like to know whether it is recommended to keep "no ip route cache" command on the core or distribution. What is the performance affect of having this command on these boxes?
Edison Ortiz Wed, 01/30/2008 - 09:11
You should use fast-switching instead of process-switching at all times, if possible.
The performance depends on the box but you will definitely see a decrease.
Attached you will find a document on performance with comparisons
