Adding subscriber to existing 6.1.1 cluster?
Jan 30th, 2008
  • Bronze, 100 points or more
Quick question - I have a customer who is running UCM 6.1.1. They want to add another Subscriber, there is no bootable 6.1.1 media on CCO. Customer needs to build a 6.0 Sub and then upgrade to 6.1.1. When they build the Sub, it asks for Pub info and when it verifies the Sub, it comes back with version mismatch. Any ideas on how to get around this?
Tommer Catlin Wed, 01/30/2008 - 09:36
  • Green, 3000 points or more
When you are just starting off with the 6.0 disc, it will ask you if you want to load any updates or patches, this is where you point it to the 6.1. files. Remember to merge the two files for 6.1.
cheers
