I need an info about the Cisco's CCNP Recert
Jan 30th, 2008
I've read on your web site that for recertify the CCNP curriculum need only to pass one professional exam of the 642-xxx series.
link:
http://www.cisco.com/web/learning/le3/le2/le37/le10/learning_certification_type_home.html
in the bottom of the page
My precise question is:
Is possible to recertify my CCNP with the exam CVOICE (642-432)?
Many thanks for your help because really I can't find no one that can give me a secure answer!
Best regards,
Massimo.
Brandon Buffin Wed, 01/30/2008 - 08:56
Massimo,
Yes, CVOICE is a professional level 642 exam. This will recertify your CCNP.
Hope this helps. If so, please rate the post.
Brandon
massimo.angeloro Thu, 01/31/2008 - 08:41
Hi bbuffin,
thanks for your answer...
but I've another doubt because I've read in my traking system tool of my csco account that exist 2 types of ccnp (v1 and v2).
For ccnp v2 effectively need only to pass one exam professional (for example CVOICE) or ccie but for v1 need to pass the composite exam...
did you have an explanation about this?
or...
did you know other forums that have answer to mine problem?
did you know if there is an cisco's email that I can contact to have another confirmation of your idea?
thanks another time,
Massimo.
Brandon Buffin Thu, 01/31/2008 - 09:54
Massimo,
You can use the Certifications Online Support link to the right of this post to open a case regarding this question.
Brandon
