ajagadee Wed, 01/30/2008 - 09:50
  • Cisco Employee,
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
Can you change the above statements to the below configuration and let me know how it goes.
crypto dynamic-map outside_dyn_map 65535 set transform-set ESP-3DES-MD5
Also, if this does not fix your issue, please post the outputs of "deb cry is" and "deb cry ipsec" when you are trying to connect using the VPN Client along with the current configuration from the Pix.
Arul
** Please rate all helpful posts **
as1207dc01 Wed, 01/30/2008 - 11:59
Well, you got me on that one. How do you set up "deb cry is" and "deb cry ipsec" log? I am learning Cisco so your help is very important.
Thank you,
