Layer 3 fragmentation
Jan 30th, 2008
Is fragmentation taken care on layer 3 switch compared to a router.
I have 2 deafult gateways in my network, one is on the router and the other on the switch which are in the same VLAN.
When i try to access the other side of the network which is a different subnet, by using the router interface as default gateway then i have good connectivity, but if i use the switch SVI as the default gateway the i face performance issues.i can see no errors or drops across any ports.
