Error upgrade from ccm 4.2.3 to 6.0.1a with DMA
system say:
The installation has encountered a unrecoverable internal error. For further assistance report the following information to your support provider.
Script "/usr/local/cm/script/ W1 PostInstall "4.2.3" /usr/local/cm/ /common/download/windows/ /common/log/install/capture.txt" exited with errors (1)
The system will now halt.
Overall Rating: 5 (1 ratings)
Anonymous (not verified) Tue, 02/05/2008 - 09:58
The failure corresponds to the absence of the definition of the TypeProduct 30013. This is typical of the presence of a delete file among your CSV files. Refer this bug for more details: CSCse53281
chad.bentilla Tue, 02/05/2008 - 12:27
This only works on DMA v5. I got the same error in DMA v6.1a and there is no such file as delete.csv in the tar file.
jawad1979 Mon, 03/03/2008 - 15:48
I'm having the same problem on 6.0(1a), and there is no delete*.csv in the tar file.
How can we solve it out?
jawad1979 Tue, 03/04/2008 - 15:09
I have followed the workaround, but it did not solve the problem.
jawad1979 Wed, 03/05/2008 - 17:38
Seems I deleted the wrong file according to the workaround. When I corrected this, it works!
Jaime Valencia Thu, 03/06/2008 - 07:53
thx for the update i had been looking for any other cause for the error but that bug just kept coming up on every case i looked into, thought this could be a new bug.
let's hope the guy that posted the question is up and running after applying the WA
