Upgrading ASA5520 Failover from 721 to 723
Jan 30th, 2008
  • Bronze, 100 points or more
What is the best way to upgrade my current ASA5520 Failover from 721 to 723 with minimal effect on my production network.
TIA
Overall Rating: 5 (1 ratings)
ajagadee Wed, 01/30/2008 - 09:59
  • Cisco Employee,
Since you are upgrading from 7.2(1) to 7.2(3), you should have zero downtime. But, I would always check and make sure that your failover is working properly with 7.2(1) before you bring in another variable into the equation, which is 7.2(3) :-)
Please refer the section "Performing Zero Downtime Upgrades for Failover Pairs" in the below URL.
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/mswlicfg.pdf
Arul
** Please rate all helpful posts **
