site-to-site VPN , Source IP address
Jan 30th, 2008
How we can specify the source ip address in IPSec configuration? it means when we have multiple ip address on the interface and we want to use a secondary ip address as source ip address for specified peer in IPSec configuration.
Brandon Buffin Wed, 01/30/2008 - 13:46
You can specify the interface used as the source, but not an IP address. You can do this with the command:
crypto map local-address
Would it be possible to move the secondary address to a loopback interface? If so, you could use the command mentioned above to source the tunnel from the loopback address.
Hope this helps. If so, please rate the post.
