NAT Problem with Remote Access?
Jan 30th, 2008
My office runs a small business server with a Cisco 1811 in front. I need to access ports 80 and 443 from the outside so I used a static NAT for the server IP. I also setup IPSec VPN on it. When I remote in, I can access anything on the network except for the server which is NAT'ed. If I remove the NAT, I can access the server through the VPN. Any idea why this is happening? What part of the config would you need to see to better assist in resolution?
dongdongliu Wed, 01/30/2008 - 19:47
maybe "below" is needed
access-l 100 deny ip host (server_ip)(vpn_peer_ip) (netmask)
access_l 100 per ip (server_ip) any
ip nat inside source list 100 pool nat_pool
ip nat pool nat_pool (server_ip)
