01-30-2008 12:43 PM - last edited on 03-25-2019 09:26 PM by ciscomoderator
I am getting the following error when trying to restart services on my subscriber, from the Publisher:
"Connection to the Server cannot be established(System Date of Local Node not in Sync with Remote Node Https Certificate issue date and expiry date)"
Any ideas?
Thanks everyone!
Ben
02-05-2008 01:27 PM
this issue could be releated to broken SQL subscription.
Run the DBLHelper.exe Utility on the Publisher Server from the c:\program files\cisco\bin and check for all the green faces in the Utility. Refer to Using DBLHelper to Reestablish a Broken Cisco CallManager Cluster SQL Subscription for more information.
http://cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801e7ddf.shtml
If there are red smilies in the DBLHelper.exe output then complete the instructions in the procedure in Reestablishing a Broken CallManager Cluster SQL Subscription with Cisco CallManager.
Reset the passwords on the servers in the cluster with CCMPWDChanger Utility in a sync.
Also reset the CTIManagers on each server.
04-10-2008 01:32 PM
Ben,
Did you get a solution, I am running into the same issue.
