IPsec Nating
Jan 30th, 2008
To build site to site VPN tunnel, one site is using ASA5504, the other site is using LinksysWEV54G. Linksys is doing nating, one public ip address 140.x.x.1, and one subnet private ip address 192.168.1.0 running DHCP. Somehow, we have a 1811 router connect to Linksys via F0/0, and we have machines running 10.10.10.x/24. In the router 1811, can we run nating? Please see below router 1811 configurtion:
interface FastEthernet0
ip address dhcp
ip virtual-reassembly
duplex auto
speed auto
ip nat outside
interface FastEthernet1
no ip address
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
ip route 0.0.0.0 0.0.0.0 FastEthernet0
no ip http server
no ip http secure-server
ip nat inside source list 7 interface FastEthernet0 overload
no cdp run
access-list 7 permit 10.10.10.0 0.0.0.255
As you see, there are double nating on one site. Here are my concerns:
1) I have no experience on Linksys. Does 10.10.10.0/24 can pass traffic through Linksys and back to ASA one the other site ideally?
2) Does router 1811 configure ok?
Please help!
Rick Morris Fri, 02/01/2008 - 07:58
  • Silver, 250 points or more
Just so I understand the set-up.
You have a Tunnel built
One site has one router ASA
The other site has a Linksys and a 1811
The tunnel terminates between the Linksys and the ASA
What is the purpose of the 1811?
Why is the tunnel set on the linksys and not the 1811?
What is the purpose of the linksys?
I am trying to understand the set-up and why the need for the config you have, running the double nat.
