01-30-2008 02:02 PM - edited 03-15-2019 08:31 AM
I've always had a suspicion that my dial-peers are not functioning like I think they should, but haven't ever been able to prove it. Obviously this is somewhat of a minor issue since we're able to place/take calls without any serious problems, but when I look at the log it seems as though there is a lot of unnecessary "matching" going on. Another issue is that I cannot block certain incoming numbers as I'd like. I created the rules below:
voice translation-rule 6
rule 1 reject /^1234567890/
voice translation-profile BLOCK
translate calling 6
dial-peer voice 1011 voip
translation-profile incoming BLOCK
translation-profile outgoing OUT
destination-pattern 9(1?)[2-9].........
voice-class codec 1
session protocol sipv2
session target dns:chcg.global.voip.mcleodusa.net
incoming called-number .
dtmf-relay rtp-nte
but the incoming translation profile is ignored completely. The call gets through without a hitch. I will attach a copy of my debug log and see if that makes sense to anyone. It does seem to be picking the correct dial-peer (probably based on the "incoming called-number ." line), but it doesn't reject the number. Strangely, if I change the rule to rewrite the incoming number to a blank string, this works. It blanks the caller ID on my end. So I know that the translation-profile is working to some degree.
Let me know what you're thinking. I can provide any extra logs necessary.
Thanks.
pk
01-30-2008 02:43 PM
Hi, is the incoming a SIP circuit? chances are, reject has been tested/supported for ISDN only.
01-31-2008 05:37 AM
It is indeed a SIP circuit. I never thought about that being the problem. Perhaps I'll have to open up a TAC case and see I can verify that. If that's the case, it saves me lots of troubleshooting time :).
Thanks.
01-31-2008 06:39 AM
You can use COR, or a "prefix" technique, to match an incoming DP with "answer-address" then route to a non-existent destination, or disconnect script, like one that I wrote:
01-31-2008 08:36 AM
I opened a TAC case and here's what I found. The issue was with how the translation profile was being applied in the dial-peer. There is a specific call-block command for the purpose of rejections.
So now my config file is as follows:
rule 1 reject /^3127266700/
rule 2 reject /^2817909977/
translate calling 6
call-block translation-profile incoming BLOCK
call-block disconnect-cause incoming user-busy
voice-class codec 1
dtmf-relay rtp-nte
You can choose how you want the call to be rejected in the second call-block command. I chose user-busy because I'd like the caller to waste as much time as possible reaching us in the future :).
For more info: http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_command_reference_chapter09186a00801a7f17.html#wp1212098
Hope this helps someone.
pk
01-31-2008 08:51 AM
Very good info, thanks!
01-30-2008 03:42 PM
Im having almost the same of problem on ASA5400xm IOS 12.4.(9)T6 but with the translation-profile outgoing.
Here is my config:
!voice translation-rule 10
rule 1 /^520232\(16[4-9].\)/ /\1/
rule 2 /^520232\(18[0-5].*\)/ /\1/
rule 3 /^520281\(54[0-3].\)/ /\1/
rule 4 /^520761\(60[4-9].\)/ /\1/
rule 5 /^520377\(59[6-9].\)/ /\1/
rule 6 /^520281\(39[0-5].\)/ /\1/
rule 7 /^505525\(47[4-9].\)/ /\1/
rule 8 /^505525\(49[0-3].\)/ /\1/
voice translation-profile CYRA
translate called 10
dial-peer voice 50001 voip
description =====================> VOIP TO TUCCCMSUB01
translation-profile outgoing CYRA
preference 3
service session
destination-pattern 52023218[0-5].
voice-class codec 1
session target dns:TUCCCMSUB01
dtmf-relay cisco-rtp h245-signal h245-alphanumeric
ip qos dscp cs3 signaling
no vad
