01-30-2008 02:41 PM - edited 03-05-2019 08:49 PM
I have a 1721 With a 100 BaseT ( Fastethernet0(192.168.0.254)) and a 10 baseT (WIC1ENET Ethernet 0(192.168.1.254)). I am trying to get the router to route traffic from 1 port to the other. I have a ADSL Router (192.168.0.1) the other side of the 1721, I just want it to route internet traffic to me and vice-versa. I have add ed the route, removed it tried adding a default route. I suspect it may be a command that I have missed. I have made sure the Ehternet I/f's are up and addes ip routing.
Any suggestions.
01-30-2008 02:56 PM
"internet traffic"... hmm.. I don't see any mention of NAT anywhere. If you are hoping for the ADSL router to translate a subnet other than 192.168.0.0/24, you may be in for a treat.
Most /if not all/ SOHO devices only allow you to NAT their current internal subnet.
You can test if routing is indeed working by pinging from the 1721 to the ADSL router by sourcing from the 192.168.1.254 interface or just place a device on that subnet and ping the 192.168.0.1 - that's as far is going to go without NAT'ng. Ah, you will also need a route from the ADSL router to the 192.168.1.0/24 network via 192.168.0.254 interface.
HTH,
__
Edison.
01-30-2008 03:10 PM
Thanks for the quick reply.
The ADSL router is "Nating". I started with a p.c. and the ADSL router, got an internet connection, great. Introduced the 1721 inbetween the two, changed the gateway IP address of the P.C. and added the route. I am going to try the pings you have suggested.
Again thanks for the quick reply.
Mark
01-30-2008 03:13 PM
Mark,
Your ADSL router won't NAT multiple subnets.
01-30-2008 03:35 PM
OK, Thanks for your help.
Time to get the books out again.
Mark
03-06-2008 03:40 PM
Mark,
Why not configure the ADSL router to bridge rarther than route, set up a dialer function on the Cisco router to do your PPOE/PPOA authentication and do all the functions you need on the cisco device ie NAT, routing etc etc.
Imran Khan
03-10-2008 03:53 AM
Thanks Imran,
In the end thats what I did. Went out and got a WIC1-adsl. Popped it in and hey presto, configured the dialing, routing etc and alls well.
Thanks.
Mark
