FXO rotary configuration
Overall Rating: 5 (2 ratings)
pcameron Thu, 01/31/2008 - 03:01
Use the preference command under the POTS dial peers to set up a order of outbound hunting. Preference 0 is the default, so it does not show in the config, so leave it off your first dial peer, then add preference 1-9 for the other dial peers.
Paolo Bevilacqua Thu, 01/31/2008 - 03:13
voice-port x/y/z
trunk-group pots
dial-peer voice 9 pots
destination-pattern 9T
trunkgroup pots
This allows you to configure a single DP to control all lines. You can also set other properties under "trunk group pots"
