CISCO 3620 IOS REQUIRE & IMFORMATION FOR UPGRADE
Jan 30th, 2008
i HAVE 3620 ROUTER I would like to upgrade
can somebody tell me which IOS it will support ..
cisco#Sh version
IOS (tm) 3600 Software (C3620-I-M), Version 11.2(8)P, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1997 by cisco Systems, Inc.
Compiled Mon 11-Aug-97 19:50 by ccai
Image text-base: 0x600088E0, data-base: 0x6044A000
ROM: System Bootstrap, Version 11.1(19)AA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc
1)
lmgcorp uptime is 2 days, 20 hours, 29 minutes
System restarted by power-on
System image file is "flash:80180008.bin", booted via flash
cisco 3620 (R4700) processor (revision 0x81) with 24576K/8192K bytes of memory.
Processor board ID 08359640
R4700 processor, Implementation 33, Revision 1.0
Bridging software.
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
Basic Rate ISDN software, Version 1.0.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
8 ISDN Basic Rate interface(s)
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
spremkumar Thu, 01/31/2008 - 01:29
  • Red, 2250 points or more
The output which you have pasted here shows 2 different hosts. (cisco# and Imgcorp in the uptime). has it been taken from a single router or from different routers.
You can make use of the following tool to find out the ios which can fit into your current hardware config...
http://tools.cisco.com/Support/Fusion/FusionHome.do
regds
Edison Ortiz Thu, 01/31/2008 - 07:31
  • Hall of Fame,
    Founding Member
You need to upgrade your DRAM and Flash as current IOS for the 3620 require at least 64MB DRAM and 16MB Flash.
You currently have 32MB DRAM and 8MB Flash.
HTH,
__
Edison.
Danilo Dy Tue, 02/05/2008 - 05:53
  • Blue, 1500 points or more
That depends on what IOS Feature set you need.
The minimum IOS for 3620 is 12.3.25 (GD) which requires minimum of 48MB DRAM and 32MB FLASH. Others requires 64MB DRAM and 32 MB FLASH. Since you are upgrading, you rather upgrade to 64MB DRAM and 32MB FLASH
You also may need to purchase the new IOS if you currently don't have maintenance contract with Cisco or you are upgrading to a different IOS Feature set.
Dandy
